Problem with heat transfer model
Hi i have i problem with a heat transfer polygon, the thing is that i put a thermal insulation, but i don't know why the temperature in all the polygon is the one i put as the exterior
1 Reply Last Post 15.11.2011, 19:05 MEZ
Posted: 1 decade ago 15.11.2011, 19:05 MEZ
if you have an isolated object and except for one side, and you do a stationary study you will en up at the same temperature everywhere, you constant T boundary will provide or extract the amount required to stabilise the temperature, and in stationary you wait an "infinite " long time.
If you solve in temporal, you will see the temperature change gently depending on the thermal diffusivity alpha = k/rho/Cp your model size and the time steps you choose
There is one case where noting happens in time and statioanry solving. It is when the intial temperature is set to T0, and your control boundary is set to the same value T0
Hi if you have an isolated object and except for one side, and you do a stationary study you will en up at the same temperature everywhere, you constant T boundary will provide or extract the amount required to stabilise the temperature, and in stationary you wait an "infinite " long time. If you solve in temporal, you will see the temperature change gently depending on the thermal diffusivity alpha = k/rho/Cp your model size and the time steps you choose There is one case where noting happens in time and statioanry solving. It is when the intial temperature is set to T0, and your control boundary is set to the same value T0 -- Good luck Ivar
