OIL fluid
Carlos Perez de la Blanca Castellano
Could anyone pass me the file of an oil with properties over 523K or more???
In the Comsol library i just find ENGINE OIL with has the properties determined until 473K
Carlos
2 Replies Last Post 19.11.2011, 09:40 GMT-5
Posted: 1 decade ago 19.11.2011, 06:53 GMT-5
Hi!!
Please help me!!i need it!!
Hi!! Please help me!!i need it!!
Posted: 1 decade ago 19.11.2011, 09:40 GMT-5
I suppose that is because most oils will boil or take fire at higher temperatures, therefore their "physical properties as liquides" are not provided. The best is to search on the web for some mineral oil name and see if you can find something more about your need there
Hi I suppose that is because most oils will boil or take fire at higher temperatures, therefore their "physical properties as liquides" are not provided. The best is to search on the web for some mineral oil name and see if you can find something more about your need there -- Good luck Ivar
