Frequency Domain Study- new frequency range and step ignored
Acoustic-Structure Interaction(acsl)/Study/Step1:Frequency Domain/Study Settings: range()
I've noticed on several occasions that when I change the range and step to new setting the new range and step is ignored and Comsol runs the old settings. I've tried many things but the only thing that worked was to create a new Study with the new range & step settings. Any other ideas that work?
Karel
1 Reply Last Post 22.11.2011, 13:11 MEZ
Posted: 1 decade ago 22.11.2011, 13:11 MEZ
I can remember there was some issues in the early 4.0 but not since.
One thing, if you change something inside the lover study steps nodes, COMSOL considers that you have made a "custom" study sequence, so it will regenerate a new Study case.
When you change the main range in the main study entry, COMSOL generates a lower level node with the parameters copied, if you change these lower level nodes, before (haven't experienced this since 4.1) then this is not overwritten. even if you change the range in the main study node.
In any case, if it's systematic, you should send the info to "support". Here, on the FORUM, we are all users and cannot do that much
Hi I can remember there was some issues in the early 4.0 but not since. One thing, if you change something inside the lover study steps nodes, COMSOL considers that you have made a "custom" study sequence, so it will regenerate a new Study case. When you change the main range in the main study entry, COMSOL generates a lower level node with the parameters copied, if you change these lower level nodes, before (haven't experienced this since 4.1) then this is not overwritten. even if you change the range in the main study node. In any case, if it's systematic, you should send the info to "support". Here, on the FORUM, we are all users and cannot do that much -- Good luck Ivar
