model.param.get does not return complex values
I set a parameter to a complex value by:
model.param.set('v1', 4.5+j*2)
However, when I try to access the parameter later by
model.param.get('v1')
All I get is
4.5
I am using comsol4.2a and matlab 2011a on a 64 bit linux machine.
Does the error occur when I am setting the parameter value or when I am accessing it.
In other words, is 'v1' correctly set to the complex value, and it is just the model.param.get that is not
working properly?
Or, is it model.param.set which is not setting 'v1' correctly?
I would appreciate any help.
Thank you,
Emi
3 Replies Last Post 28.11.2011, 07:15 MEZ
Posted: 1 decade ago 27.11.2011, 20:55 MEZ
I'm not sure you can retrieve the comlex value in one call, have you tried to recall twice with a real() and imag()
Hi I'm not sure you can retrieve the comlex value in one call, have you tried to recall twice with a real() and imag() -- Good luck Ivar
Posted: 1 decade ago 27.11.2011, 22:20 MEZ
No, the model.param.set does not work if you set a parameter to a complex number.
Currently, I am getting around this by turning the complex value into a string and
setting the parameter to that string.
Example:
v1 = 4.5+j*2.5
v1String = num2str(v1);
model.param.set('v1', v1String);
Then when I call
I get the correct value:
4.5+j*2.5
So, I guess to pass complex values to model.param.set, you need to convert it to a string first.
Emi
No, the model.param.set does not work if you set a parameter to a complex number. Currently, I am getting around this by turning the complex value into a string and setting the parameter to that string. Example: v1 = 4.5+j*2.5 v1String = num2str(v1); model.param.set('v1', v1String); Then when I call model.param.get('v1') I get the correct value: 4.5+j*2.5 So, I guess to pass complex values to model.param.set, you need to convert it to a string first. Regards, Emi
Posted: 1 decade ago 28.11.2011, 07:15 MEZ
Then I think it's worth to get that confirmed by "support". I find it somewhat astonishing, but OK, I hardly use matlab now with V4
Hi Then I think it's worth to get that confirmed by "support". I find it somewhat astonishing, but OK, I hardly use matlab now with V4 -- Good luck Ivar
