Parametric sweep for initial angle in rotating mesh
Torkel Svenson Hagström
Hello!
I was wondering, is it possible to do a parametric sweep for the initial angle of a rotating mesh in version 5.4? I have tried to make one but for some reason I end up getting the same results in the sweep for all angles, and the rotating domain remains in the same position for all angles when I look at the results. It is strange because if I insert just one initial angle and manually simulate for each value individually I get different results for different angles as one would expect. Is there any way to make it work as a parametric sweep as well?
Thank you in advance!
2 Replies Last Post 16.10.2019, 05:32 GMT-4
Posted: 5 years ago 01.10.2019, 09:09 GMT-4
Did you see my response to your earlier post?
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 5 years ago 16.10.2019, 05:32 GMT-4
Hello!
I didn't see any response before now, apologies for the late response (I didn't get any notification from COMSOL about your response and then I was recommended to use the Support instead, so I forgot about the whole thing...). But yes, I've seen the response to the previous post, thanks a lot for your help!
Best regards Torkel
Hello! I didn't see any response before now, apologies for the late response (I didn't get any notification from COMSOL about your response and then I was recommended to use the Support instead, so I forgot about the whole thing...). But yes, I've seen the response to the previous post, thanks a lot for your help! Best regards Torkel
