absolute tolerance for thermal stress problem
So I am modeling the 2D transient freezing of a cylinder of tissue with 80% water (my model is a 2D wedge as Im assuming L >> D). I am using a quasi-static viscoelastic model with time dependent temperature equation in the thermal stress module. Therefore I expect a 7% increase in total volume (under the assumption volumetric expansion of water is 9%). My initial radius is 0.01m and so I expect a final radius 0f 0.0103 which tells me I expect a final displacement of 3.5*10^-4 m.
Now my question is, what do I set the relative and absolute tolerance? I know you should set the absolute tolerance one order of magnitude less than the displacement in order to get any accuracy. But which displacement do I consider? DO I use the displacement at each time step or the displacement from the initial and final states? During each time step the displacement is ~10^-8 m.
Currently, I am using relative tolerance = 0.0001 and absolute tolerance = 10^-6 to 10^-8. Any suggestions? I have been looking at the effects of varying tolerances and increasing elements. I see that as I decrease my absolute tolerance, the convergence plot osscilates more and more.
Alex
3 Replies Last Post 20.12.2011, 10:09 GMT-5
Posted: 1 decade ago 11.12.2011, 05:17 GMT-5
I assume your oscillations come from numerical instabilities, do not forget that the binary number representation has a limited resolution (check the variable "eps", and consider sqrt(eps) as the best of the best, I would rather use 100 to 1000 times sqrt(eps) as a reasonable relative limit). And this is not COMSOL limitation it's a number theory limitation of binary numbers applicable to any software.
My way to check convergence is to compare the results when I increase the resolution, does the result vary or converge ? Mostly FEM is for a few % precision, not to extract 18 decimals. But that depends on your model and it's finesse, are all hypothesis for the physics model correct and within limit, are ALL physics presented, ...
Hi I assume your oscillations come from numerical instabilities, do not forget that the binary number representation has a limited resolution (check the variable "eps", and consider sqrt(eps) as the best of the best, I would rather use 100 to 1000 times sqrt(eps) as a reasonable relative limit). And this is not COMSOL limitation it's a number theory limitation of binary numbers applicable to any software. My way to check convergence is to compare the results when I increase the resolution, does the result vary or converge ? Mostly FEM is for a few % precision, not to extract 18 decimals. But that depends on your model and it's finesse, are all hypothesis for the physics model correct and within limit, are ALL physics presented, ... -- Good luck Ivar
Posted: 1 decade ago 13.12.2011, 13:00 GMT-5
The 100-1000 times eps^.5 turned out to be in my original estimate for absolute tolerance of 10^-6. When I had decreased tolerance to 10^-7 to 10^-9 there was almost no improvement. Thank you so much for the explanation.
-Alex
The 100-1000 times eps^.5 turned out to be in my original estimate for absolute tolerance of 10^-6. When I had decreased tolerance to 10^-7 to 10^-9 there was almost no improvement. Thank you so much for the explanation. -Alex
Mohammad Hossein Babaei
Posted: 1 decade ago 20.12.2011, 10:09 GMT-5
Hi, How can I check the numerical value of "eps"?
Hossein
Hi, How can I check the numerical value of "eps"? Thanks Hossein
