Impedance analysis - Piezo
I am using COMSOL 2d Axisymmetric model for the imdepance analysis.
I've used a probe defining es.nD*es.omega for the current measurement. Using point graph plotting and 1[V]/(abs(bnd1)), I am trying to create impedance plot.
For 2D model, the same procedure works with es.nD*es.omega*thickness.
But since I want model cyclindrical structure, I have to use 2d Axisymmetric model. I've attached my model. Could someone help me out with this problem.
Thank you.
Regards, GA
3 Replies Last Post 10.01.2020, 21:09 MEZ
Posted: 6 years ago 09.01.2020, 22:25 MEZ
Updated: 6 years ago 09.01.2020, 22:25 MEZ
While you certainly CAN integrate the electric displacement, it is more straightforward to do a global evaluation of the terminal admittance (es.Y11). Or for impedance magnitude abs(1/es.Y11).
Posted: 6 years ago 10.01.2020, 10:42 MEZ
Thank you very much for the message. Please check the attachment.
I checked with 2D model. I used both 1[V]/(abs(bnd1)) from the boundary probe (Current) and abs(1/es.Y11) as global evaluation. The one with boundary probe has Impedance of 10^4 range and for the global evaulation it is 10^2 range.
Both the impedance curve falls on the same line, but the scale is different.
Thank you very much for the message. Please check the attachment. I checked with 2D model. I used both 1[V]/(abs(bnd1)) from the boundary probe (Current) and abs(1/es.Y11) as global evaluation. The one with boundary probe has Impedance of 10^4 range and for the global evaulation it is 10^2 range. Both the impedance curve falls on the same line, but the scale is different.
Posted: 6 years ago 10.01.2020, 21:09 MEZ
Well either or both are wrong. Since I don't know what or where you are probing I will put my money on es.Y11.
Since you know the permittivity of the piezo (at least approximately) a good check is verifying that the capacitance away from resonance is correct.
Well either or both are wrong. Since I don't know what or where you are probing I will put my money on es.Y11. Since you know the permittivity of the piezo (at least approximately) a good check is verifying that the capacitance away from resonance is correct.
