Units in COMSOL - Problems
Today I found what seems to be a flaw in COMSOL 4.0. I declared a parameter "h" (planck's constant) and put the following expression (I copy/pasted it here:)
6.62*10^-34 [m^2*kg/s]
Then, I declared parameter "test" as
h
So, I would expect both "test" and "h" to have the same units, but instead, "test" has units "m" (meters). Why does this happen? I am not quite trusting COMSOL on units anymore, unless I made a terrible mistake. Could someone help me?
4 Replies Last Post 17.01.2012, 08:50 MEZ
Posted: 1 decade ago 20.12.2011, 08:39 MEZ
You should generally avoid variable or parameter names that are predefined by Comsol, such as h (for the mesh element size) and test (for the test operator). Once you rename "h" to something else, it should work as expected. Note that Comsol also predefines some physical constant, and you can refer to Planck's constant as "h_const".
Posted: 1 decade ago 21.12.2011, 21:44 MEZ
Thanks! That fixes the problem :)
Posted: 1 decade ago 17.01.2012, 04:27 MEZ
Where can I find a complete list of physical quantities predefined in COMSOL? I mean, like h_const for Planck's constant.
Posted: 1 decade ago 17.01.2012, 08:50 MEZ
You'll find a list in the Comsol User's Guide: table 3.5, page 123 in version 4.2a.
