How to stop COMSOL Events at an exact value?
I am simulating battery cycling using the Events interface. The voltage limits are V_high = 2.45 V and V_low = 2 V. The events are working okay, but there is a problem that I have encountered multiple times. The events never stop at those particular values/limits, as one can see in the figure below. Sometimes the events change at 2.43, sometimes at 2.46 but never at 2.4500 V or 2.000V as I would like to. I'm thinking that the time step (which is now strict) might help with this, but decreasing the time step for a long simulation time would slow the model significantly. I have also checked the option "Store solution before and after events" in the solver output settings.
Can anyone help me to make the events stop/change at exact values without compromising the computation speed?
Unfortunately I cannot send the model, but here are some extracts from the event settings:
3 Replies Last Post 17.02.2020, 16:38 GMT-5
Posted: 6 years ago 17.02.2020, 13:27 GMT-5
Updated: 6 years ago 17.02.2020, 13:51 GMT-5
Paul,
I had similar issues and increasing the scaling in the solver settings for the respective variables improved the situation. It can make the solver more sensitive to the criterion.
Maybe I should add that in case the time stepping is not resolving the event sufficiently then you won't get around reducing it.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Paul, I had similar issues and increasing the scaling in the solver settings for the respective variables improved the situation. It can make the solver more sensitive to the criterion. Maybe I should add that in case the time stepping is not resolving the event sufficiently then you won't get around reducing it. Cheers Edgar
Posted: 6 years ago 17.02.2020, 15:47 GMT-5
This actually solved the problem, but I think it needs some work with the values to increase the precision and model stability. Thank you very much for the help!
Posted: 6 years ago 17.02.2020, 16:38 GMT-5
I am happy I was able to help.
Edgar J. Kaiser
www.emphys.com
