Modelling laser-heating of sample
Posted 10.01.2012, 05:34 GMT-5 Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.1 8 Replies
I am a new user of the COMSOL package and I wish to try and simulate the heating of a spherical structure via a laser beam from one side. The first model I have created is simply a sphere with half of it having a boundary condition to simulate the laser beam but this is not entirely representative of the problem. The laser beam will be able penetrate the sphere and provide heating at certain depths and not just heating the surface of the sphere. In terms of dimensions, the laser beam is larger than the spherical structure.
I only have the basic Multiphysics module so will extra modules be required to solve my problem?
Thanks in advance.
principally you can do everything with the basic module if you are willing to implement the equations of your model by yourself.
If you want to make your life easier and you are willing to spend the money then the heat transfer and the RF module might cover your physics.
Cheers
Edgar
Something which I forgot to add and is rather crucial, is that the temperature jump which I wish to simulate is from 1.5K to 300K. In this temperature temperature range, a number of physical properties such as the specific heat capacity and thermal conductivity will change drastically so is COMSOL able to simulate these changes too?
Cheers
Edgar
Steven
Furthermore, the headings in the table are t and f(t) suggesting a time and a function of time rather than temperature which is what I want, should I be concerned with this?
Why not load in a material with a T dependence and see how its done, that should give you the tips needed
I've managed to find a material that has a property variance in temperature but I can't seem to apply it to my model. The physics I am using is the coefficient form of a PDE but even though it appears I can assign the model with a material, when I assign the model with another material, I get the same result from the simulation.
Any suggestions?
Thanks.
have you checked the help about:
Variable Naming Convention and Scope
New Functionality in Version 4.2a
"New material container variable root.material simplifies access to material data. For example, "root.material.rho" is the density ρ as defined by the materials in each domain in the geometry. For plotting, you can type the expression material.rho to create a plot that shows the density of all materials."
Suggested Content
- KNOWLEDGE BASE How does COMSOL Multiphysics handle complex-valued numbers and problems in the frequency domain?
- BLOG Best Papers and Posters from the COMSOL Conference 2016 Munich
- KNOWLEDGE BASE Solving electromagnetic heating models with high-frequency loads
- FORUM Laser heating of a sample
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling?
