Ground plane connection of a antenna
Hi all,
I am working on a antenna model using the RF module and am wondering if anyone had any thoughts on setting up a shielding condition using a ground plane.
I have a two arm spiral antenna with the arms having a BC of 'perfect conductors', between the arms I've used a 'lumped port'. The arms are modelled below a 50mm cavity which again has a BC of 'perfect conductor' on the bottom and the sides are open. The actual design would have this plane connected to ground.
How should I setup this ground connection in the RF module?
Thanks in advance,
David
4 Replies Last Post 20.01.2012, 14:49 MEZ
Posted: 1 decade ago 16.01.2012, 12:13 MEZ
David,
I think you don't need an explicit ground connection. This would only set a DC reference potential. This doesn't affect the radiation properties of your antenna.
Cheers
Edgar
David, I think you don't need an explicit ground connection. This would only set a DC reference potential. This doesn't affect the radiation properties of your antenna. Cheers Edgar
Posted: 1 decade ago 16.01.2012, 14:22 MEZ
Hi Edgar,
Thanks for your comments. It does seem to act as a shield from the field plots - I just want to ensure there is no floating potential on the surface.
David
Hi Edgar, Thanks for your comments. It does seem to act as a shield from the field plots - I just want to ensure there is no floating potential on the surface. Best regards, David
Posted: 1 decade ago 16.01.2012, 15:41 MEZ
Ive done something very similar to this.
It would be great if you could upload a snapshot of your geometry.
Regards
Glenston
Hi, Ive done something very similar to this. It would be great if you could upload a snapshot of your geometry. Regards Glenston
Posted: 1 decade ago 20.01.2012, 14:49 MEZ
Hi Glenston,
This model we are developing is a prototype antenna for a commerical partner; therefore, I cannot upload the model.
I'll have a look and see if there are any other similar models which I can upload.
David
Hi Glenston, This model we are developing is a prototype antenna for a commerical partner; therefore, I cannot upload the model. I'll have a look and see if there are any other similar models which I can upload. Best regards, David
