Error Circular variable dependency detected.
I got this error
- Variable: mod1.icp.sigmazz
- Geometry: 1
- Domain: 2 3 5
Whot it is mean ?
Variable sigma have defined in material browser.
Thank very much.
By.
1 Reply Last Post 18.01.2012, 13:33 MEZ
Posted: 1 decade ago 18.01.2012, 13:33 MEZ
a circular dependency means that you have defined an input variable on some results or output variables.
This happens when you set up very non-linear models, but also often when you happen to use a variable name that COMSOL already has defined internally.
You need to go down the chain from your "sigma" definition and check how its defined and if some of the variables might have a name conflict with COMSOL internal variables names
Hi a circular dependency means that you have defined an input variable on some results or output variables. This happens when you set up very non-linear models, but also often when you happen to use a variable name that COMSOL already has defined internally. You need to go down the chain from your "sigma" definition and check how its defined and if some of the variables might have a name conflict with COMSOL internal variables names -- Good luck Ivar
