Nonconverging
I got this error in my simulation, How should I solve it
Nonlinear solver did not converge. In Velocity u, Pressure p: No convergence, even when using the minimum damping factor. Time: 370.89765902442974 s. Last time step is not converged.
Thanks in advance, Reza
2 Replies Last Post 14.04.2020, 02:46 MESZ
Posted: 5 years ago 07.04.2020, 20:44 MESZ
Make sure yo uhave well posed prolbem and well defined and imposed boudary condtions. If flow field it not converging, apply point pressure contraints.
Posted: 5 years ago 14.04.2020, 02:46 MESZ
I had the point pressure constratints. Actually I solved the problem by changing the scaling method for the velocity field (in study/solver configurations/Solution 1/dependent variable/velocity filed/scaling/initial value based.)
Hope it will help others as well.
I had the point pressure constratints. Actually I solved the problem by changing the scaling method for the velocity field (in study/solver configurations/Solution 1/dependent variable/velocity filed/scaling/initial value based.) Hope it will help others as well.
