Change a function during a time simulation
Posted 27.01.2012, 09:31 GMT-5 Parameters, Variables, & Functions Version 4.2a 1 Reply
Hi everybody,
I have a 2D Comsol model in that there are 4 functions interpolation (Global definition>Interpolation); each interpolation is a temperature field such as T=T(x,y)
My model is a time dependent study; till now I have used this model with one by one Temperature field T(x,y), over the entire range of time, but now I should simulate a real work (so, with the lowest temperature field initially, and after with the highest temp. field, and in conclusion again with the lowest, for instance).
I make an example to be more clear: if I have T1(x,y) and T2(x,y), and the time of my simulation is 0:1:24 h, I would create a work condition with T1 for 5h, then a linear increase from T1->T2 for 1h, afterward T2 for 5h etc.
I tried to use "Definitions>Piecewise", but I have an error, I think because it is needed in the "function" (in Piecewise) a constant value*argument; so, each T=T(x,y) is time indipendent, but it is not a value, but a function in (x,y).
And, if you suggest me to use this Piecewise, which is the name of the time used by the time dependent study (or rather, the name of the "argument" in Piecewise)?
I hope I was clear
Thank you in advance
Fabio
I hope I was clear
Fabio
1 Reply Last Post 27.01.2012, 10:28 GMT-5
