Modeling Change In Impedance As A Particle Flows Past Electrodes
Posted 05.05.2020, 19:56 MESZ Electromagnetics, Microfluidics, Particle Tracing for Fluid Flow Version 5.5 0 Replies
The below post is related to an archived discussion
I am trying to mix the two example Particle tracing and electrophoretic movement. [https://uk.comsol.com/model/dielectrophoretic-separation-of-platelets-from-red-blood-cells-17013] Impedance change due to particle. [https://www.comsol.com/model/electric-impedance-sensor-7704] Still, I could not able to see any change in impedance due to the particle; irrespective of their size. I guess there is some coupling from partcle tracing to electric field. However, I can see the dieletrophoretic effect, even at 1V. which is quite small electric field for dielectrophoretic effect.
Many Thanks in advance. Vishnu
Hello Vishnuram na
