Trouble importing complex solids designed in blender
Hi all,
I'm new to comsol, and since I don't have access to a wind tunnel currently I'm trying to test lift and drag coefficients on some 3d models. The model is a 3d lizard made in blender and it is very complex. I usually export the model from blender as an stl, then use a separate program to convert it to a step file.
Unfortunately I'm having some trouble importing my model (which I designed in blender) as a solid. I can import it as a mesh stl, however when I try to import as a solid step file I get "internal error in geometry processing, internal error code 900".
I tried completely simplifying the model in blender, and when I do it imports as a solid, but it takes hours to load and comes up with dozens of errors.
What can I do to successfully load in this complex model? Should I give up on using blender (which I'm now acquainted with) in favor of a different program? Any ideas?
Thanks, Jaden
1 Reply Last Post 17.06.2020, 23:14 MESZ
Posted: 5 years ago 17.06.2020, 23:14 MESZ
Updated: 5 years ago 17.06.2020, 23:15 MESZ
Hi Jaden,
Before you give up on Blender, or on whichever program you've been using to convert the stl into a step file, try importing your stl in version 5.5. 5.5 is much stronger than 5.3 in that area.
Jeff Hiller
Hi Jaden, Before you give up on Blender, or on whichever program you've been using to convert the stl into a step file, try importing your stl in version 5.5. 5.5 is much stronger than 5.3 in that area. Best regards, Jeff
