Impossible to Couple Lubricant Shell with Solid Mechanics
Posted 21.02.2012, 07:07 MEZ Fluid & Heat, Modeling Tools & Definitions, Parameters, Variables, & Functions 2 Replies
Lubrication Shell: Thin film between the solid wall and the channel base.
The edge you select is the "solid wall" and if that edge is from a "solid mechanic" domain then you can couple it with the "lubrication shell" (Solid Wall Defromation)
However, the software does not ask you for any adge to define the "Channel Base", how does it know the propieties of the "Channel Base"? How to define the "Channel Base"?
Thanks again.
Thanks again.
2 Replies Last Post 21.02.2012, 11:43 MEZ
