Henrik Sönnerlind
COMSOL Employee
5 years ago
07.07.2020, 09:46 MESZ
If it is acceptable that the moving support has some finite size (at least one element), then the approach described in this blog post can be used:
https://www.comsol.com/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation
Note however that a support with finite size will cause a reaction moment in a beam-like structure.
A moving point support can fairly simply be implemented in a parametric solution, but not in a time dependent study. If, however, the structural mechanics problem is not truly time dependent, it can be solved using a parametric sweep.
Henrik Sönnerlind
COMSOL
5 years ago
12.07.2020, 21:01 MESZ
Dear Henrik,
Thanks a lot for your reply,
May i know how a moving point support is implemented in Parametric study. Can we draw/define a point or a line which is parameter based?
- Is it possible to define the coordinates of a point or a line which is patameter based? It was only accepting Numerical values
- When aplying time dependent Diritchelt condition in thermal studies for a specific Temperature value, we use an expression like if (condition, Temp value, ht.Tvar). Similary is it possible in Structural module to define a time dependet Diritchlet condition ? ( Displacement zero). If yes may I know which variable should i use in place of ht.Tvar ?
Best
Aswin
Dear Henrik,
1. Is it possible to define the coordinates of a point or a line which is patameter based? It was only accepting Numerical values
2. When aplying time dependent Diritchelt condition in thermal studies for a specific Temperature value, we use an expression like if (condition, Temp value, ht.Tvar). Similary is it possible in Structural module to define a time dependet Diritchlet condition ? ( Displacement zero). If yes may I know which variable should i use in place of ht.Tvar ?
Best
Aswin
Henrik Sönnerlind
COMSOL Employee
5 years ago
13.07.2020, 13:21 MESZ
The coordinates of a point can depend on a parameter. That is one way of moving the support if you have added a Prescribed Displacement to that point. This, of course, will require a remeshing for each parameter value, since the geometry is changed.
You can also create a mesh independent moving support, as in the attached model. There, a mesh independent point load is moved, and its value is selected so that the displacement at its location is zero. This is done using a probe, the location of which is given by a parameter.
Your last question: For a Dirichlet condition in structural mechanics, you should use one of the displacement degrees of freedom e.g. 'v'.
Henrik Sönnerlind
COMSOL
