Meshing around a contact point
Posted 28.02.2012, 10:07 GMT-5 Mesh Version 3.5a 2 Replies
In my 2D model, I have a circle contacting with a straight boundary. The solution also shows quite singular behavior around there. I need to assign extremely fine mesh there to get stable solution.
What I'm doing now is to manually draw an array of dummy points in the region as control points. However, since this array of points has dimension much smaller than the whole model, I often get the error message "failed to insert point". I must play with the point array to make it work. I would like to know if there's any guide to avoid such error.
Thanks!
Thanks!
2 Replies Last Post 29.02.2012, 14:26 GMT-5
