Jeff Hiller
        COMSOL Employee
                                5 years ago
                                25.08.2020, 15:28 GMT-4
                        Updated:
                                5 years ago
                                26.08.2020, 11:38 GMT-4
                                                    Hello Omkar,
Frequently laser heating is modeled by solving the heat transfer equation under the assumption of a heat source profile applied to the surface. In that approach, you only solve the heat transfer equation, subject to the assumed thermal load. This keeps the model quite simple, and suitable when the material is opaque at the wavelength in question. The heat source can be made to move over time if need be; this blog post presents several ways of achieving this.
For more sophisticated approaches that consider partially transparent materials, see also this other blog post on laser-material interactions.
    Jeff Hiller
                            Hello Omkar,
Frequently laser heating is modeled by solving the heat transfer equation under the assumption of a heat source profile applied to the surface. In that approach, you only solve the heat transfer equation, subject to the assumed thermal load. This keeps the model quite simple, and suitable when the material is opaque at the wavelength in question. The heat source can be made to move over time if need be; [this blog post]( https://www.comsol.com/blogs/3-approaches-to-modeling-moving-loads-and-constraints-in-comsol/) presents several ways of achieving this.
For more sophisticated approaches that consider partially transparent materials, see also [this other blog post](https://www.comsol.com/blogs/modeling-laser-material-interactions-in-comsol-multiphysics/) on laser-material interactions.
                                5 years ago
                                13.10.2020, 10:05 GMT-4
                                                    Hi Jeff, thank you very much for your advice,
I already seen this post and unfortunatelly i did not find a useful solution for me. I agree with you with the use of a simple model by defining the heat source profile on the surface but
this is the point I am unable to solve.
Thank you...
Thank you...
