inconsistent unit (electromagnetic waves-frequency domain)
Hello, i write this expression for an electric field (sqrt(240nP)/w)exp(-((y-S/2)^2+z^2)/w^2)exp(j2(pi/L)*((y-S/2)^2)+z^2+x^2). the expected answer should be [V/m]. But i get the message ΄INCONSISTENT UNIT΄. what am i writting wrong?? P: laser power w [m] S [m].
Any help will be valuable thanks in advance
1 Reply Last Post 28.08.2020, 19:55 MESZ
Posted: 5 years ago 28.08.2020, 19:55 MESZ
Updated: 5 years ago 28.08.2020, 22:09 MESZ
Hello Irene,
In your formula,
  • What are the dimensions of n? Did you specify them in the model?
  • Is "240" dimensionless? If not, make sure to declare its units between square brackets (e.g. ).
Jeff Hiller
Hello Irene, In your formula, * What are the dimensions of n? Did you specify them in the model? * Is "240" dimensionless? If not, make sure to declare its units between square brackets (e.g. 9.81[m/s/s]). Best, Jeff
