                                12.03.2012, 01:05 GMT-4
It seems that the frequency sweep is working. However, if the step is less than 10, the software shows errors and stops. The error is shown just before the resonance frequency. For example if I run the seep from 300 Hz to 700 Hz at a step of 10 Hz, the model works but it does not for the same range and a step less than 10 Hz. Does anyone have an idea as to why this is happening?
I have one more question though. What is the difference between frequency domain analysis and frequency domain modal analysis?
-Sankha
-Sankha
                                12.03.2012, 01:42 GMT-4
There is something else which I do not understand either. If I use a finer mesh this error message pops up "Failed to find a solution for all parameters, even when using the minimum parameter step. The relative error (X) is greater than the relative tolerance Returned solution has not converged.". Only If I use a normal or coarse mesh (which are there by default) the module runs successfully. I wonder why this is happening?
-Sankha
-Sankha
                                12.03.2012, 11:36 GMT-4
when you do frequency sweeps (particularly without any damping) then often the peaks are very narrow, and you need to manually tweek the frequency steps you ask for to carefully resolve the peaks/resonances and if possible try to avoid just THE resonance frequency
                                17.07.2013, 09:28 GMT-4
                                                    Try add a Boundary Load, then right click on it and select Harmonic Load.
                                14.02.2014, 06:54 GMT-5
It seems like the Frequency Domain-Modal Study needs a load with "Harmonic Perturbation" in order to work and unlikewise the Frequency Domain Study works only with a simple load.
The reason is not quite obvious to me from the references, shall anyone know and explain this part?
                            [QUOTE]
[/QUOTE]
                                Henrik Sönnerlind
        COMSOL Employee
                                14.02.2014, 10:38 GMT-5
You can find a discussion about this in the posting from May 23, 2013 in
www.comsol.com/community/forums/general/thread/35454
Henrik
http://www.comsol.com/community/forums/general/thread/35454
Henrik
                                14.02.2014, 16:39 GMT-5
                                                    Thanks Henrik,
I will check it out and continue there then.
Nicolas
                            Thanks Henrik,
Nicolas
                                24.02.2014, 19:12 GMT-5
                                                    Is it possible to apply a non-zero prescribed displacement boundary condition with harmonic perturbation for a frequency domain modal study? I am trying to apply a frequency dependent displacement (using the global variable "freq") but the values does not seem to be updating with each frequency step.
The documentation says that in order for a modal analysis to work,  there should be no non-zero displacement BCs.  Can this be the reason why my displacement variable does not update?
                                Henrik Sönnerlind
        COMSOL Employee
                                27.02.2014, 13:43 GMT-5
Since all eigenmodes have zero displacement where there is a constraint, any superposition of them will also be zero there. This is why it is not possible to have nonzero prescribed displacements in any modal superposition.
If it is really necessary,  there is an old and ugly engineer's trick:
1. Replace the constraint with a *very* large mass. This will not change the eigenvalues much.
2. In the reponse analysis, replace the prescribed displacement with a force which moves the mass as much as you need. Since the mass is so large, you can use F=m*a=-m*u*omega^2.
But beware; selecting a proper value of  the mass is not trivial. If you want to try it, start with some simple models.
Henrik
Henrik
