Edgar J. Kaiser
Certified Consultant
5 years ago
20.10.2020, 13:24 MESZ
Guilherme,
in your model all boundaries except the heat sources are insulated. Therefore the temperature rises to infinity and breaks the solver.
You need a heat sink. This can e.g. be a temperature boundary. The heat you bring in must go out somewhere.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Guilherme,
Cheers
Edgar
5 years ago
20.10.2020, 17:14 MESZ
Updated:
5 years ago
20.10.2020, 17:23 MESZ
Dear Edgard,
Thank you for the answer. Just so I see if I understand I should set one of my edges with a heat flux Q that I want to vary from 1 to 10 W and then set my remaining boundaries to a temperature? (e.g: 25 degC)
How I would see the temperature rise caused by this Q then?
EDIT: by doing as I exemplified above I can now properly simulate. My new question now is if I can somehow evaluate the points and values of my min and max temperatures (e.g: (1,1,1, 25) where 1,1,1 would be x,y,z and 25 would be the temperature).
Dear Edgard,
Edgar J. Kaiser
5 years ago
20.10.2020, 21:31 MESZ
You can check the max/min operations in 'Nonlocal couplings' and respective Max/Min datasets in the postprocessing.
Also point probes and point cut datasets may be of interest.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Cheers
Edgar
5 years ago
21.10.2020, 12:59 MESZ
Updated:
5 years ago
21.10.2020, 13:13 MESZ
Dear Edgar,
I actually ran the simulation and extracted the results using a Derived Value and created a Surface Maximum. However this doesn't agree with my analytical model and I am not sure if then I am correctly extracting the value. In theory my thermal resistance would be given by
which for d = 0.1mm, k = 401 and t = 1mm would yield a thermal resistance of 317 degC/W, while from simulation I get around 2degC/W.
What I am doing wrongly here?
Dear Edgar,
I actually ran the simulation and extracted the results using a **Derived Value** and created a **Surface Maximum**. However this doesn't agree with my analytical model and I am not sure if then I am correctly extracting the value. In theory my thermal resistance would be given by
R_{thermal} = \frac{t}{k_{cu}*pi*\frac{d}{4}^2}
Edgar J. Kaiser
5 years ago
21.10.2020, 17:29 MESZ
Check if your model realizes this kind of thermal resistor. I think the barrel of the cylinder should be thermally isolated in this case.
Edgar J. Kaiser
www.emphys.com
5 years ago
22.10.2020, 09:10 MESZ
Thank you Edgar, it seems now that this works. This is my first try with COMSOL and in my mind I was doing so (but I ovewrote the isolation by setting a temperature boundary).
Edgar J. Kaiser
5 years ago
22.10.2020, 10:14 MESZ
Good to hear that it works for you now.
Edgar J. Kaiser
www.emphys.com
