Getting the seconds elapsed during the simulation with Matlab
Good afternoon.
Can anybody help me?
How can I access the seconds elapsed during the simulation?
Which function can help me? and how can I use it? Maybe mpheval or mphglobal?
I want to make a parametric frequency sweep starting at 100Hz and raising the frequency every second elapsed.
1 sec -> 100hz 2 sec -> 110hz 3 sec -> 120hz ....
So I need to get the real time elapsed to evaluate.
1 Reply Last Post 10.12.2020, 04:08 GMT-5
Posted: 5 years ago 10.12.2020, 04:08 GMT-5
Updated: 5 years ago 10.12.2020, 20:42 GMT-5
Hi, Victor. First, you need to define ''Times'' in the study stetting as [t0, dt, t0+dt], and then select a strict time stepping. In the Matlab, you can use '' t1 = mphglobal(model,'t','solnum','end') to access the time of the last step, and then use to ''model.param.set('t0',[num2str(t1) '[s]'])'' to reset the initial time. For each time loop, you can change what you need. But i think you can just use Comsol to achieve the process.
All the best,
Songcai
Hi, Victor. First, you need to define ''Times'' in the study stetting as [t0, dt, t0+dt], and then select a strict time stepping. In the Matlab, you can use '' t1 = mphglobal(model,'t','solnum','end') to access the time of the last step, and then use to ''model.param.set('t0',[num2str(t1) '[s]'])'' to reset the initial time. For each time loop, you can change what you need. But i think you can just use Comsol to achieve the process. All the best, Songcai
