Non-conservation of mass
Hello all,
I solved for the laminar flow equation for a eprforated pipe. I set up the boundary conditions such as I defined the inlet and outlet flow rates and set a pressure at the holes. Upon evaluation of the flow rate (surface integral of velocity), the mass does not seem to be conserved (ie: total for the holes does not equal in-out). The laminar flow equation was set to incompressible.
Could this be a factor of mesh quality?
1 Reply Last Post 20.04.2012, 16:02 MESZ
Posted: 1 decade ago 20.04.2012, 16:02 MESZ
Bonjour Mélanie,
Do you integrate the velocity magnitude (U) on the boundaries? Because, for example in 2D, U = sqrt(u^2+v^2), i.e., all velocity components end up positive, therefore giving an incoherent mass balance. You should integrate u, v and w along the boundaries to verify mass balance.
Bonjour Mélanie, Do you integrate the velocity magnitude (U) on the boundaries? Because, for example in 2D, U = sqrt(u^2+v^2), i.e., all velocity components end up positive, therefore giving an incoherent mass balance. You should integrate u, v and w along the boundaries to verify mass balance.
