Solid with trapezoidal section
Posted 19.04.2012, 18:19 GMT-4 Version 4.2 1 Reply
I am trying to create a solid block with a trapezoidal cross section.
I tried creating a trapezoid using the polygon option and then converting that to a surface and finally, extruding the surface to form the block.
However, I get an error when I try to convert the polygon to surface. It says at least two vertices are required.
Can anyone suggest alternate methods to create the block?
1 Reply Last Post 19.04.2012, 19:17 GMT-4
