How to plot electric field along a broken line
I'm hoping someone can advise me on this problem.
I've recently been using Comsol 4.2 to get the electric field. The geometry I am using has a sawtooth boundary. And I am trying to get the electric field along the sawtooth. But I got trouble when I tried to define the Data Sets. It seems that "Cut Line 2D" can only be used for a straight line. However, what I want is a broken line.
Any advice?
Thanks in advance
3 Replies Last Post 04.05.2012, 07:58 MESZ
Posted: 1 decade ago 03.05.2012, 23:40 MESZ
what about selecting the boundary and plotting either along the arc ("s"), or along a coordinate x,y,z ?
Hi what about selecting the boundary and plotting either along the arc ("s"), or along a coordinate x,y,z ? -- Good luck Ivar
Posted: 1 decade ago 04.05.2012, 00:13 MESZ
Hello Ivar,
Sorry, I did not get it. Could you explain it a little bit more.
Xinping
Hello Ivar, Sorry, I did not get it. Could you explain it a little bit more. Xinping
Posted: 1 decade ago 04.05.2012, 07:58 MESZ
you said you ave already a boundary, then "my way" would be to make a "Line plot" select the sagged boundary and plot the electric filed.
Optionally you can replace the plot "x" axis (by default the "arc" length), by an expression such as "x" or "y" to use a coordinate
Hi you said you ave already a boundary, then "my way" would be to make a "Line plot" select the sagged boundary and plot the electric filed. Optionally you can replace the plot "x" axis (by default the "arc" length), by an expression such as "x" or "y" to use a coordinate -- Good luck Ivar
