Edgar J. Kaiser
Certified Consultant
5 years ago
22.04.2021, 14:01 GMT-4
you just use it in any expression with the syntax you already found in the documentation. The only requirement is that the solution you are referencing must already exist.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
5 years ago
22.04.2021, 14:27 GMT-4
Hi Edgar,
Thank you for your reply.
Yes, I do I understand this. But I want to take the solution from my Frequency dependent solution and have it as an initial condition in my second time dependent solution. I tried to define it as withsol('sol1',expr) in the initial values of variables solved for under my time dependent study but I can't define an expression there.
I have attached my file as well.
Thank you,
Alkistis
Hi Edgar,
Thank you,
Alkistis
Edgar J. Kaiser
5 years ago
22.04.2021, 16:57 GMT-4
Alkistis,
yes withsol() can't be used there. To use a solution as initial condition you just choose the respective solution from the list that you see.
I have never tried it, but I think a frequency domain solution can't be used as initial condition for a time dependent study. There is no time in the frequency domain. The model oscillates at the study frequency in a dynamic steady state.
What do you want to achieve with this approach? The Example.prefs file is useless btw.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Alkistis,
Cheers
Edgar
5 years ago
24.04.2021, 16:12 GMT-4
Hi Edgar,
Thank you for your reply and interest.
I solved the issue. I wanted to combine a frequency dependent study solving for the acoustic pressure with a two time dependent studies. The first one was solving for the laminar flow and the second one for the particle tracing module. I chained them using the "Variables not solved for" in the solvers. However, the "withsol()" operator was required in the acoustic radiation force section which is the force exerted by the acoustic pressure field (standing waves) on the particles.
(Might be useful for anyone interested about particle trapping/standing waves applications)
Hi Edgar,
