Robert Koslover
Certified Consultant
5 years ago
05.05.2021, 22:19 GMT-4
You've imported your 2D file into your 3D geometry. It is apparently a set of lines, without surfaces. And it is not actually "in" the workplane you then created afterward. I suggest you instead import your 2D file directly into the workplane of interest (the software will let you do that; try it.) You also need to form surfaces to extrude, or else you will extrude a frame, not a volume. I suggest you try that and see if you can figure out the rest. If not, see how far you can get and repost your model.
5 years ago
06.05.2021, 13:02 GMT-4
Thank you for your reply. You are correct it has to be 2d surface inorder to extrude which I ignored. I fix this issue by using SolidWorks CAD design.
