Can't edit equation system
Hi, all
I'm trying to modify some terms in equation system. I can input expressions I need. However, they automatically change to some strange expressions when I go back to check them after leaving the page. These automatically generated expressions are not the default ones either. Many redundant items and parentheses appear, such as ((((Jy)+(emw.Jiy))+(emw.Jdy))+(emw.Jiy))+(emw.Jdy).
Does anyone know how I can stop this strange thing?
Thanks!
1 Reply Last Post 03.06.2012, 09:17 MESZ
Posted: 1 decade ago 03.06.2012, 09:17 MESZ
Feedback
I finally get around the problem, but still don't know why this happens.
For example, the default expression is Expr. What I'm trying to input is Expr1 + Expr. If I input Expr1 + Expr, later when I come back to the equation system edit page, they will become something like (Expr1 + Expr) + Expr. Then I just input Expr1, it automatically changes to (Expr1) + Expr, which is the correct one.
However, this trick does not work for an arbitrary expression.
Feedback I finally get around the problem, but still don't know why this happens. For example, the default expression is Expr. What I'm trying to input is Expr1 + Expr. If I input Expr1 + Expr, later when I come back to the equation system edit page, they will become something like (Expr1 + Expr) + Expr. Then I just input Expr1, it automatically changes to (Expr1) + Expr, which is the correct one. However, this trick does not work for an arbitrary expression.
