Doubled values in Total normal heat flux.... why?
Posted 29.05.2012, 11:37 MESZ Heat Transfer & Phase Change, Results & Visualization Version 4.2 3 Replies
I have a little problem with an heat transfer problem.
I'm simulating a 2d problem modelled by a square box of air with a circular solid (silicon) heat source in the middle.
Using the "heat transfer in solid " physic I set a boundary temperature of the square box and a 10 W total fixed heat source for the circular solid.
The stationary problem converges...
I tried to evaluate the line integral for the total normal heat flux on the circular heat surface, and I obtained a correct 10 W integral, the same thing doing the line integral on the boundary of the air box.
Then I tried to insert in the "heat transfer" physic a "Heat transfer in fluids" node for the air box.
At this point, solving again the problem, I find the same exact solution for temperature, etc, but if I evaluate the normal heat flux line integral on the heat source boundary I find a doubled value of about 20W while on the square air box I still find 10W
The interesting thing is that on the heat source boundary the "Total Normal Heat Flux" is exactly the double of the "Total heat Flux Magnitude". How is it possible?
UPDATE:
I tried to change the physic: I used a "heat transfer in fluids" physic for both the domains, and I obtain the10W "normal heat flux line integral both for the heat source. As soon as i configure an "heat transfer in solids" for the source, the line integral doubles!!!
Is this a bug or there is something I can't understand?
thank you!
UPDATE:
thank you!
3 Replies Last Post 29.05.2012, 15:57 MESZ
