07.06.2012, 14:37 MESZ
Hi Siyad,
As far as I know it is not possible the change the type of boundary condition during a simulation. However there are some workarounds for this problem.
You could solve your problem with the temperature boundary for until t=25000s, store the solution, manually change the boundary condition to a heat flux one, and use the stored solution as an initial condition for the second stage. When you only need to do a few simulations this might be a solution.
When you need to do a lot of simulation you could try and implement this in MATLAB, using the functionality that lets you run Comsol models in MATLAB.
The last solution I can think of is dependent on the kind of problem you are trying to solve. Maybe there is a way emulate a heat flux condition with the use of a temperature condition with the use of specific functions. Or the other way around (emulate temperature cond. as a heat flux one). Then again this really depends on your physics, so you might want to post the model?
Hi Siyad,
07.06.2012, 15:44 MESZ
these changed of BC conditionally linked to the solver studies will be possible in V4.3 somewhere in the post these days
