08.06.2012, 09:46 MESZ
with the optimisation module you can build complex optimisation chemes, but if it is "just" to fit a single parameter you can do it as well via an ODE, you add the variable as a dependet variable, load in the experimental results and use the difference between the simulation and the data (squared to easier search for the minimum) as driver for your optimisation variable
Try it out on a simple model first, I believ there is at least such a model in HT model library somewhere
14.06.2012, 19:30 MESZ
Thank you Ivar for your valuable comments.
I will be needing optimization for several parameters, supposedly 4 to 8. I tried to find a simple model in the model library which fits the desired parameter(s) with respect to experimental data but couldn't find any. Do you know where can I find a simple example model for optimization?
Thanks.
Tolga
Thanks.
Tolga
14.06.2012, 19:51 MESZ
I do not really know about a model library with many variables. You can take a look at my Model Exchange "Zernike development" example its a 4.2a model, now I cannot remember if I made it with the optimisation or only as ODEs. Have a try
14.06.2012, 19:59 MESZ
Hi Ivar,
Thanks again. I will check your model.
Tolga
Hi Ivar,
Tolga
15.06.2012, 19:28 MESZ
Hi Ivar,
I checked your model and also a model in the model library -material_property_fitting- (if it is not there, update your library). I have successfully obtained the optimization of the parameters.
The example model in the library is also good for a start.
Thanks again.
Tolga
Hi Ivar,
Thanks again.
Tolga
26.06.2012, 23:27 MESZ
Hello Tolga,
Can you explain how you made it? I want to do an optimization of thermal conductivity for a 2D model in COMSOL, i'm a beginner, so if you have time to explain the method it will be great.
Thanks.
Hello Tolga,
Thanks.
Jeff Hiller
COMSOL Employee
26.06.2012, 23:34 MESZ
Hi Tolga,
You may find this model interesting as well for reverse modeling of a material property:
www.comsol.com/showroom/gallery/4410/
Best of luck in your work,
JF
Hi Tolga,
http://www.comsol.com/showroom/gallery/4410/
JF
26.06.2012, 23:55 MESZ
Hi Wane,
I am using COMSOL 4.2a. There is a tutorial model in the model library which you can study in order to build your own model. It does parameter fitting for thermal conductivity and specific heat capacity on a 1-D geometry using heat transfer and optimization modules.
Browse the material library and look for the model named "material_property_fitting". It is under Optimization Module / Tutorial Models. If it is not there, update your model library to download it.
Jean-Francois, thank you for the heads up on the other model.
Tolga
Hi Wane,
Tolga
28.06.2012, 09:22 MESZ
Thanks Tolga for your answer.
So, i tried to update the model library, but i didn't find that model. Can you attach the file with the pdf model?
Thanks.
Thanks.
02.07.2012, 23:02 MESZ
Hi Wane,
I am sorry but it could be inappropriate for me to send one of COMSOL's own models here. Please ask a COMSOL employee for that.
However, the model should be in the updated model library / Optimization branch. Are you sure you have the optimization module?
Tolga
Hi Wane,
Tolga
