Calculate & compare two separate simulations on the same geometry
I have done a laminar flow simulation (including the inertial term), and now would like to do the same simulation (identical geometry, meshing, boundary conditions) with the inertial term neglected.
Then I would like to compare the two solutions by creating the difference (DataSets-Join shoud do that) and plot the result as a 3D-Slice.
How do I go about calculationg two seperate solutions in the same Model?
Thank you.
1 Reply Last Post 21.06.2012, 11:15 GMT-4
Posted: 1 decade ago 21.06.2012, 11:15 GMT-4
have you checked the data set join (or is it only in v4.3 ?)
Hi have you checked the data set join (or is it only in v4.3 ?) -- Good luck Ivar
