boundary condition of solar radiation
hi...
I have some question about solar radiation model (external radiation source)
Applies to the wall of building, only one side of wall is applied the solar incident radiation.
I was modeling the wall as 2D (rectangle wall)
How should I set the boundary conditon of wall
1. only one side of wall ( solar incident radiation)
surface-surface radiation? or surface-ambient radiation?
2. others of wall
adiabatic? or surface-surface radiation? or surface-ambient radiation?
my geometry is in attached file
1 Reply Last Post 26.06.2012, 02:32 GMT-4
Posted: 1 decade ago 26.06.2012, 02:32 GMT-4
the best is to check each one, read the help and look at the equations:
Heat flux gives an incident boundary (surface) flux in W/m^2 with some options
Convective cooling corresponds to the removal of heat by air convection (not that much different from the previous, but it "bins-in" the internal variables convection part)
Surface to ambient is for radiative exchange to a large outside domain at a given temperature
Inflow heat flux mimics a virtual domain
For solar flux, if I read the new 4.3 doc correctly you must turn on the surface to surface or re radiating surface check box this will add new items in the right-click list (was probably the case in 4.2 too )
Hi the best is to check each one, read the help and look at the equations: Heat flux gives an incident boundary (surface) flux in W/m^2 with some options Convective cooling corresponds to the removal of heat by air convection (not that much different from the previous, but it "bins-in" the internal variables convection part) Surface to ambient is for radiative exchange to a large outside domain at a given temperature Inflow heat flux mimics a virtual domain For solar flux, if I read the new 4.3 doc correctly you must turn on the surface to surface or re radiating surface check box this will add new items in the right-click list (was probably the case in 4.2 too ) -- Good luck Ivar
