Moving a large laser beam across a surface
Posted 09.07.2012, 15:33 GMT-4 Wave Optics, Heat Transfer & Phase Change, Heat Transfer 3 Replies
I am a new COMSOL user and would like to simulate the heating of a plate with a slow moving laser beam (v=1mm/s). The beam spot size is very large, approximatley 15mm diameter, and thus can not be modeled as a point source.
I am thinking of modeling it as a boundary heat source. I have a function, f(x,y), that defines the local intensity (W/m^2) of the laser beam. The function resembles a gaussian beam. I was thinking that I would simply substitute (x-v*t) for x in my function, in order to get the function to move in the x direction (v is the velocity of the beam, t is time). My boundary heat source is then f(x-v*t, y).
I have been searching to see if there are other posts that discuss this method for moving a boundary heat source across a part, but I have been unsuccessful.
I have tried it out it everything appears to be OK - the heat source appears to move across the part at the appropriate speed. Is there any reason why this method should not be used?
Blake
Blake
3 Replies Last Post 16.09.2012, 22:31 GMT-4
