Edgar J. Kaiser
        Certified Consultant
                                4 years ago
                                08.01.2022, 06:11 GMT-5
contacts can be a little tricky and you will probably need to play with the settings. Check the application library, maybe you find some useful hints.
You will probably need a moving mesh as well.
Cheers
Edgar
    Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
                                4 years ago
                                13.01.2022, 08:29 GMT-5
                                                    Thank you for the answer. I have been playing a lot with the settings. So, far, I can't find a way to have a converging model. But I will keep trying and also exploring the library.
Cheers
Nasim
Cheers
Nasim
                                4 years ago
                                17.01.2022, 11:18 GMT-5
I have been playing with different settings of the contact and the solvers. But I can't seem to find a properly converging model. In my model (attached to this post), I have two different voltages applied to two conductive materials encapsulating a piezoelectric material. This is to enable a latera movement of the whole structure along the ground. There is an inverted silicon substrate in the model as well. I started with free contacts to simplify the model, and then continue with friction.
For now, I want to see how a stationary solver converges, then I will move on to a time-dependent solver, in order to model a sinusoidal input voltage.
If somebody could look at my model and tell me where I have made mistakes, I would really appreciate their help. At this point, I am very confused and the settings might look random.
But the most recurring wanrning (which I guess causes a non-converging model) is "inverted mesh element" near coordinates at which there is no geometry. Changing the mesh did not help in this respect at all :(
kind regards
Nasim
kind regards
Nasim
