Time function of the lightning current
Hello, I will wonder if someone explains to me how to add lightning current function in COMSOL. I was trying to use the ‘analytic function’ node from the definition section of the COMSOL to provide the time depending function of the lightning current (for analysis purposes). Unfortunately, I did not achieve anything that has any sense. The equation which characterised this function is: i=I/k×(t⁄T1)^10/〖1+(t⁄T1)〗^10 ×exp((-t)⁄T2) Another thing is how to use this function as an input to the terminal of the metal structure (all in 3D simulation)?
6 Replies Last Post 31.01.2022, 20:02 MEZ
Posted: 4 years ago 12.01.2022, 12:08 MEZ
Mateusz,
it should be straightforward to implement the analytic function. What is the problem in detail?
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Mateusz, it should be straightforward to implement the analytic function. What is the problem in detail? Cheers Edgar
Bouderbala Abdelkader
Posted: 3 years ago 31.01.2022, 01:41 MEZ
I have the same problem
Posted: 3 years ago 31.01.2022, 02:34 MEZ
Posting your (reduced) model will yield the most informed responses.
However- when simulating very abrupt and short transients it is important to choose the time stepping settings carefully.
Posting your (reduced) model will yield the most informed responses. However- when simulating very abrupt and short transients it is important to choose the time stepping settings carefully.
Posted: 3 years ago 31.01.2022, 15:04 MEZ
The problem is, I don't know how to enter time-varying data into the comsol
Posted: 3 years ago 31.01.2022, 15:07 MEZ
Did you find a solution to this problem?
Posted: 3 years ago 31.01.2022, 20:02 MEZ
Updated: 3 years ago 31.01.2022, 20:06 MEZ
Hello Bouderbala,
The COMSOL GUI is interpreted, so you can type mathematical expressions in the user interface pretty much like you write them on a piece of paper. This has been discussed many times in this Discussion Forum (For instance, here ), and for an extensive discussion of the syntax and available function I will refer you to the documentation, which is accessed through File > Help > Documentation in the software itself. When solving a time dependent problem, "t" is time.
Jeff Hiller
Hello Bouderbala, The COMSOL GUI is interpreted, so you can type mathematical expressions in the user interface pretty much like you write them on a piece of paper. This has been discussed many times in this Discussion Forum (For instance, [here](https://www.comsol.com/forum/thread/122051/error-while-calling-external-c-function?last=2016-08-26T11:03:59Z) ), and for an extensive discussion of the syntax and available function I will refer you to the documentation, which is accessed through File > Help > Documentation in the software itself. When solving a time dependent problem, "t" is time. Best regards, Jeff
