Material Function error.
SWATHI KRISHNA SUBHASH
HI,
I am using COMSOL Multiphysics 5.4.0.388. Working with Heat trasfer and phase change with Laminar flow. I tried to defined a temperature-dependent heat capacity using a piecwise function for a phase cahneg material (solid and liquid phase). The argument is T and defined the units of the argument and function as K and J/(kgK), respectively. For solid and liquidn material I named the Cp as Cp_solid and Cp_liquid respectively. However when I enter Cp_solid(T) in the material content section it turns orange and while computing it shows error.
Unefined variable eoor.
Any suggestions will be quiet helpful.
2 Replies Last Post 22.03.2022, 12:19 MEZ
Posted: 3 years ago 19.02.2022, 01:48 MEZ
Updated: 3 years ago 21.02.2022, 03:06 MEZ
I suggest you post your .mph file to the forum.
Swathi Krishna Subhash
Posted: 3 years ago 22.03.2022, 12:19 MEZ
thank you for the response. I solved the error.
Hi, thank you for the response. I solved the error.
