02.08.2012, 20:15 MESZ
here too there are seldom a clear unique answer, yield stress levels are very shape dependent, as you easily get stress concetration around sharp edges or small holes, or defects in the material.
I often use the calculated von Mises stress, but then i use a security factor of 2-3, or more, even twice this if its my first simulation and I do not have any measurements or tests to validate my models.
You are there talking about MEMS devices, here the surface roughness can play you important games, easily a factor 10 in maximum stress levels, and you have often differences in maximum compression strength and traction strength
The best is to compare your model to some simple tests, but be sure you have measured the shapes correctly, and the surface roughness, particularly in he high stress regions
10.03.2014, 08:17 MEZ
what type physics should i choose to get deflection by applying compression and tensional forces on cantilever surfaces of pizeoresistve materials .
20.08.2015, 12:34 MESZ
@Ivar Kjelberg
sir, I am interested to model a force based piezoelectric cantilever. I dont know any tutorial or reference where a force is used to obtain the von mises stress curves. Plz tell me from what type of study you had taken and how to put forces on the tip of the cantilever
@Ivar Kjelberg
