NaN from 2D Cut Point
I'm working to export Ex values from my simulation via 2D Cutpoints. Some of the points that I am extracting values from just produce NaN. When I went back to try to plot these points on the figure directly in COMSOL they won't plot. The little red dot just does not pop up. Has anyone had this happen before? Is there anything I can do to fix it? Thanks!
1 Reply Last Post 01.05.2022, 22:18 GMT-4
Posted: 2 years ago 01.05.2022, 22:18 GMT-4
Maybe you could post your model, along with telling us exactly where to look to see your particular problem. Perhaps you are trying to plot a quantity which is literally not a number (NaN), or perhaps your point is not actually in your computational space, or perhaps your Cutpoint is not referencing your actual existing solution, or... so I recommend you post your .mph file to the forum.
Maybe you could post your model, along with telling us exactly where to look to see your particular problem. Perhaps you are trying to plot a quantity which is *literally* not a number (NaN), or perhaps your point is not actually in your computational space, or perhaps your Cutpoint is not referencing your actual existing solution, or... so I recommend you post your .mph file to the forum.
