Boundary Heat Flux
When modelling 2D heat conduction and using a heat flux boundary condition, the input allowed by comsol in SI units is W/m^2. Does this mean, that X watts/ m of x and 1m of Z? If a 2D model is assuming that the z dimension is infinite, then this could be the case? but what if the z dimension is very small and negligible?
1 Reply Last Post 06.08.2012, 22:16 GMT-4
Posted: 1 decade ago 06.08.2012, 22:16 GMT-4
In 2D heat transfer COMSOL assumes a thickness of 1.0 and no heat transfer through that thickness. In that case the ratio of the thickness to the in-plane dimensions is irrelevant (provided that you input all heat transfer/generation terms per unit thickness).
Nagi Elabbasi
Veryst Engineering
In 2D heat transfer COMSOL assumes a thickness of 1.0 and no heat transfer through that thickness. In that case the ratio of the thickness to the in-plane dimensions is irrelevant (provided that you input all heat transfer/generation terms per unit thickness). Nagi Elabbasi Veryst Engineering
