Obtain two simulations, RF Module, 4.2a
Dear All,
If I do some simulations from for wavelengths from 400nm to 1300nm, and after that from 1300nm to 2500nm, is there possible to obtain these two results in one?
Thanks in advanced.
2 Replies Last Post 08.08.2012, 11:33 MESZ
Posted: 1 decade ago 08.08.2012, 07:17 MESZ
if you try a frequency domain with a combined range of the type {range(400,100,1300) range(1350,50,2500)}*1E-9
it should work, but you can change at will the stepping, or even use only 1 range() operator. The only thing, the sequence should be STRICTLY monotonous (increasing or decreasing, and not repeating (this is no longer so in 4.3 if I have read the RN correct)
Hi if you try a frequency domain with a combined range of the type {range(400,100,1300) range(1350,50,2500)}*1E-9 it should work, but you can change at will the stepping, or even use only 1 range() operator. The only thing, the sequence should be STRICTLY monotonous (increasing or decreasing, and not repeating (this is no longer so in 4.3 if I have read the RN correct) -- Good luck Ivar
Posted: 1 decade ago 08.08.2012, 11:33 MESZ
Hello Ivar,
Thank you very much on your help.
Nikola
Hello Ivar, Thank you very much on your help. Regards, Nikola
