High Mach number flow and heat transfer problem?
We use the high Mach number flow(k-epsion) to simulate the heat transfer of the fluid and solid part. If we add no heat source in the model, the results are relatively reasonable, But when we add a boundary heat source inside the model, the temperature changes only occur in the solid part and do not affect the fluid part--there will be a temperature jump in the boundary!! Anyone knows the reason for the problem?
0 Replies Last Post 18.07.2022, 08:58 MESZ
Hello Ge Tsuna
