Formation Compressibility from Young's Modulus and Poisson's Ratio
I am am working on a poroelastic model that couples Solid Mechanics and Darrcy's Law interfaces. Since formation compressibility is a function of Young's Modulus and Poisson's Ratio, does my model account for formation compressibility if I have input the values of Young's Modulus and Poisson's Ratio?
2 Replies Last Post 20.10.2022, 22:04 MESZ
Ed Gonzalez COMSOL Employee
Posted: 3 years ago 20.10.2022, 16:48 MESZ
Hi Megan, the dried bulk modulus, K_dry, is taken from the Linear Elastic material node. If you enter the pair (E,nu), it is computed as described in the documentation https://doc.comsol.com/6.0/doc/com.comsol.help.comsol/comsol_ref_structuralmechanics.27.06.html#2330360
then, the formation compressibility is derived from Biot-Willis coefficient, alpha_B, as
C_f = alpha_B / (porosity * K_dry)
if you have data for the formation compressibility, enter the Biot-Willis coefficient as
alpha_B = C_f * porosity * K_dry
Cheers Ed
Hi Megan, the dried bulk modulus, K_dry, is taken from the Linear Elastic material node. If you enter the pair (E,nu), it is computed as described in the documentation https://doc.comsol.com/6.0/doc/com.comsol.help.comsol/comsol_ref_structuralmechanics.27.06.html#2330360 then, the formation compressibility is derived from Biot-Willis coefficient, alpha_B, as C_f = alpha_B / (porosity * K_dry) if you have data for the formation compressibility, enter the Biot-Willis coefficient as alpha_B = C_f * porosity * K_dry Cheers Ed
Posted: 3 years ago 20.10.2022, 22:04 MESZ
Thank you very much for your help, Ed! E, nu, porosity, and alpha_B are all applied to the materials in my model, so I should be set then. Thank you for linking the documentation reference!
Best.
Megan
Thank you very much for your help, Ed! E, nu, porosity, and alpha_B are all applied to the materials in my model, so I should be set then. Thank you for linking the documentation reference! Best. Megan
