18.09.2012, 09:21 MESZ
It is so strange! Previously, if the relative tolerance is lower than the fixed value, the simulaiton will converge and stop. But now......Does anyone know it why? Thank you.
Andrew Prudil
Nuclear Materials
18.09.2012, 21:55 MESZ
Are you sure you are not thinking of absolute tollerances instead of the relative tollerances?
It wouldn't make sense to say something is defined because the absolute error is less than the relative error tollerance. Think about dependent variables less than one. For example, if I am trying to calculate a concentration which is about 1e-6 and my relative error is 0.001 then I need to be converged within 1e-9 not 1e-3.
Another possiblity is that you have set a tolerance factor to a value less than 1 in your solver.
18.09.2012, 23:55 MESZ
Thank you for your response! I am very sure my setting was the relative tolerance and the tolerance factor was 1. I tried again and again, but it still could not converge. Even the previous simulation which was certainly converged can not be converged now. It is so strange....... In addition, the ErrEst was certainly much lower than the fixed tolerance.......but finally showed the simulation could not converge.
[QUOTE]
[/QUOTE]
19.09.2012, 16:41 MESZ
Now I had solved this issue. This is totally because of version! I updated the comsol tool, and then it became right.
[QUOTE]
[/QUOTE]
