Mesh Refinement around moving point
Posted 21.11.2022, 18:34 MEZ Heat Transfer, Mesh Version 6.0 0 Replies
Hello everyone,
I am currently working on model that has a (time dependend) moving load on a surface, where the path is defined in an interpolation function for x(t) y(t).
To implement a mesh refinement around that moving point i'm trying to use the adaptive meshing.
For me, this moving point and the path is particularly important, which is why I need a very fine mesh there, everything else should be as coarse as possible, as I have defined it in the starting mesh.
Currently I use the longest edge refinement and the manual interval length, because then I can specify fraction of elements in the element selection. But then I can't edit the number of refinements (what i guess would make the mesh finer than default).
If I use the automatic interval length, I can specify the maximum number of refinements, but in the element selection I can only select the rough global minimum that will result in a fine mesh also where i dont need it to be fine.
As I know the full path and time where the mesh has to be fine i was also searching for a different solution so Comsol doesn't has to search for the points where it has to remesh, but I couldn't find any.
Thanks in advance for any help!
Jan
Hello whoisjako
