Fractional derivatives model for viscoelastic material in COMSOL
Hello
I want to model a viscoelastic material in COMSOL, so I drew a block and selected a material from the software library (polyisobutylene). Then, after choosing "solid mechanics", I added a hyperelastic material so that I could select the "viscoelasticity" option.
In the "viscoelasticity" tab there's a section called "material model", which allows the following options: Maxwell generalization, standard linear solid, Kelvin-Voigt.
The thing is that I don't want to use any of those models but the fractional derivatives model, which you can see in the attached figures. What should I do?
Thank you
https://ibb.co/sqW6m3T https://ibb.co/9vMtPpJ https://ibb.co/B30wCWw https://ibb.co/RpcLRRW https://ibb.co/mGnx789
1 Reply Last Post 20.02.2023, 04:45 GMT-5
Posted: 3 years ago 20.02.2023, 04:45 GMT-5
Fractional derivatives in COMSOL are so far only supported for frequency domain analysis, that is a linear type of study. That is why they only exist for Viscoelasticity under the Linear Elastic Material node. For infinitesimal strains, there is no need to use an hyperelastic material.
Henrik Sönnerlind
COMSOL
Fractional derivatives in COMSOL are so far only supported for frequency domain analysis, that is a linear type of study. That is why they only exist for *Viscoelasticity* under the *Linear Elastic Material* node. For infinitesimal strains, there is no need to use an hyperelastic material.
