Edgar J. Kaiser
Certified Consultant
2 years ago
04.07.2023, 08:38 MESZ
Loss factor is a material property, which must be provided to the model from a datasheet or measurements.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
2 years ago
05.07.2023, 10:46 MESZ
use the PIM Method, you can calculate the loss factor
Henrik Sönnerlind
COMSOL Employee
2 years ago
05.07.2023, 13:02 MESZ
PIM (Power Input Method) is an experimental method for determining the loss factor, which as Edgar says, is a material property.
However, when using the PIM method you need to know the strain energy (or the kinetic energy) of the test object. For this purpose you can use a finite element model.
Henrik Sönnerlind
COMSOL
