intensity in acoustic
Posted 06.11.2012, 03:34 GMT-5 Acoustics & Vibrations Version 3.5a 5 Replies
Re:
when you start with COMSOL try to use only 1 physics at the time, test yourmodel physics by physics, once you have got the 3 fundamental physics working alone (with fixed values for the interconnections) then mix two and finally 3, else you will take long and get confused. It's certainyl quicker, I still apply it, 6 years after my first COMSOL model, and when I believe I'll manage without this ways, then I loose a day ;)
basically if you use frequency domain solver, all driving loads are amplitudes at the frequency given by the solver step(s). Try a few Model Library axamples, and check the webinars on acoustics on the web
Hi Ivar
thanks for your reply
I tried Model Library examples, I started COMSOL by use 1 physics then I added 2 other physics. I want to know can I change intensity in my models?
this is very important for me.
Hoping for help,thanks very much!
feri
Hi Ivar
feri
5 Replies Last Post 28.11.2012, 03:31 GMT-5
